profdant139
Nov 01, 2016Explorer III
SoundGuy, you are exactly right -- and even more so, there is the mysterious Peukert effect to think about, which would more than double my capacity.
But I am one of these belt and suspenders guys -- I use one battery at a time. The other is a spare in case the first one dies. If they are in parallel and one dies, I could be left without power. So they are independent. If and when the first one gets too low, I swap them. Due to my solar panel, I may never be forced to swap them again. This last month of boondocking, I swapped them every week, whether they needed it or not.
And red31, I take your point -- the resting periods of about half an hour may have extended the "run time." But this is sort of like the Heisenberg Uncertainty Principle -- the act of measuring something can alter the object being measured. (Didn't see that coming, did we??)
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
