BFL13
Nov 01, 2016Explorer II
When you use an inverter and a 120v appliance such as the 60w bulb he used, the inverter will draw more amps as time goes on as the battery voltage falls. Called "inverter creep" as it tries to maintain output voltage.
DC lamps dim when battery voltage falls so they draw fewer amps as time goes on.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
