grizzzman
Nov 01, 2016Explorer
red31 wrote:grizzzman wrote:
Well the reason is simple. Your 110 AH rated battery is likely rated at the C20 rate. This means that the battery amps pulled were in the 9ish rate. The more amps you pull from a battery the more heat (waste) happens. So the lower the amps pulled, the more amp hours you will get.
110/20 = 5.5, where does 9ish come from?
Its simpe realy. Care to guess what 110 ÷ by 12 will get ya? Thanks for catching my screw up!
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
