BFL13
Nov 04, 2016Explorer II
The 24 hour pulse "Recondition" session on a Vector charger does not raise battery voltage. So that is not "charging."
It is meant to be a way to desulfate. I have used this and am not sure it works. I do see that after a session of Recondition, you can get the battery to a slightly higher "full" than before, so I have used alternating Recondition sessions and high voltage charging sessions to "recover" batts when they got stuck at a "full" that was too low. (Back when I had those 27s that were so difficult to recover. Don't need to do that with 6s) It may be that just taking a day off between high voltage sessions would work the same, but I never tested for that.
Meanwhile, there is something called "pulse charging" which I suppose does raise battery voltage. I guess this would be like when an MPPT solar controller goes into Absorption and uses PWM. That is charging with rising battery voltage.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 19, 2026
