KATOOM's avatar
KATOOM
How to trace TV coax line
I haven't stayed in a camp site with this trailer which offered cable TV until recently. DVD's and antenna TV are generally what we watch. There are two TV's in the trailer but a couple other cable connections, like outside. The main TV has two cable connections on the wall behind it which consist of a plate with one coax connection combined with a 12v plug and a button which seems to power the antenna signal. There is a second single coax plate next to it without the 12v plug which seems to be the cable TV line. The TV in the bedroom area only has that single coax plate without the 12v plug but there's apparently no signal coming from that coax connection. Given its appearance I'm assuming that its also a cable TV connection but I have no way to tell. How can I test the incoming and all output coax lines in the trailer to see where they go and which ones have signal or not?
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
