DAS26miles's avatar
DAS26miles
Explorer II
Jul 13, 2015
How to Weatherproof new shoreline power cord connectors
My new ordered MH will be coming with the screw in external connector on the side of the MH with probably a 25 foot 30 amp cord . My current MH uses the older style where I disconnect the shoreline power cord from the generator in a small compartment. I have a 25 foot extension 30amp cord that I attach to a 30amp exterior power box on the side of my house. I don't want to be using the new power cord exposing it to the elements day in and day out. So I see I can buy a pigtail that will screw into the twist-on connection on the side of the MH. Then connect my current power cord to the male end of the pigtail. However, the pigtail is 18" long and the connection of the pigtail and old power cord will be uncover and exposed to rain. Any suggestions as to how to prevent water intrusion and possible shock?
    Although some manufacturers wire their trailers with a main service detachable power kit neither of my previous two trailers had one so one of the first mods I did with each was to install a weatherproof Marinco Park Power version.
    The far end of whatever cable I'm using of course terminates with a standard 30 amp male plug which plugs into the campsite 30 amp service and although it's not particularly weatherproof there's often a hinged lid of sorts over the receptacle that offers some level of moisture protection. Millions are in use and you can bet that if rain getting into this particular connection was a major issue we wouldn't be using them ... in other words, I don't worry about it at all. ;)
    That leaves any interconnections between multiple lengths of cable which is where water getting into the connection can be an issue, particularly if that connection happens to lie in a depression in the ground that later fills with rainwater. :E One should of course try to avoid allowing the connection to sit anywhere water could potentially collect by elevating / covering that connection with an inverted bucket, etc, but i instead chose to wire up my custom made 10 gauge, 30 amp extensions and dogbones using Leviton WetGuard connectors.
    We actively practice energy management when camping (e.g. turn off A/C if we want to use the microwave, etc) so our maximum current draw at any given time is always well within the ratings for these 15/20 amp versions of the WetGuard connectos but for those wanting at times to draw a full 30 amps the Leviton WetGuard Series does offer 30 amp versions. The only catch may be that unlike the 15 amp versions which are commonly available at a reasonable price at big box stores like Home Depot, Lowes, etc, these 30 amp versions are more costly and usually only sold by outlets serving the electrical trades so you may have to search a bit to find them. That said, after 15 years of use without a single issue, I would give these Leviton WetGuard connectors a HUGE thumbs up and highly recommend them to anyone looking for weatherproof connectors suitable to RV use. :B
  • As long as it is not sitting in water, it will be fine. You could get some electrical grease if you wish.
  • RoyB's avatar
    RoyB
    Explorer II
    My trailer shore power cable connector has a snap lid that covers it when not in use.
    I keep my 25-foot shore power cable coiled up inside a large bucket sitting inside the basement area when not in use.
    I too use a 50-foot 10-gauge (10-3) extension cord that is plugged inside the garage to a 20A service receptacle and runs out to the trailers. The connection to the shore power cable is using a RV30A-15A long adapter which is just laying in the middle of the yard. I did at one time take a closed lid large plastic box and and cut slots on both sides for the shore power cable and extension cord to come in and out. Then I closed the lid after I hooked both ends to the RV30A-15A adapter. The whole adapter was inside the snap lid plastic box.
    Haven't seen that box for a while now haha... I really don't see any problems with just plugging things together laying in the yard. I make sure water doesn't settle around the connections...
    Of course the best thing would be is have the trailer parked close enough to the house and install a 30AMP connection on the outside of the house and just plug directly into that.
    Roy Ken
