- Edd505ExplorerWhats to stop you from installing a shut off in the water line?
- IF your refer has a built in filter, the filter will remove the PINK in the Antifreeze and you will see clear water. Do NOT know if this degrades the operation and freeze point of the Antifreeze. Doug
- mgirardoExplorerWe have a GE Residential Fridge with an ice maker only. I have read online and watched videos for other refrigerators that have a button or a solenoid that can be jumped to force the ice maker to demand water, but there is nothing in the owners manual about either and I haven't been able to find one looking at the fridge.
Anyway, what I do is just winterize the rest of the RV, then with a mostly full bottle of antifreeze, I just leave the pump on with the suction tube still in the bottle. I leave the fridge on and wait. The first tray of cubes to come out are usually pink ice cubes, then eventually, it'll be mostly slush coming out. Once it is all slush, I know all the water is out and I am done.
When it comes time to de-winterize, we usually wait a few days of making ice cubes, throwing them out as they are made. Then after a few days, all the anti-freeze taste is gone.
-Michael - ENG2242ExplorerThanks guy’s, done.
- joebedfordNomad IIMy residential fridge has a water reservoir for chilled water. It's not on the ice tray circuit. Don't you have to winterize that too?
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
