metalmanbryan's avatar
Jun 15, 2016
how to wire generator
Hi my Name is Bryan new to the sight have a avion 5th wheel that I have been Keeping At a campground Since fuel prices Went upThe problem is when Campground is at full capacity during holiday weekends They tend to lose power I am trying to wire up my generator so I can have air conditioning Because I have a 200 pound dog that is old and cannot go without itI will include pictures of the generator hookups and hopefully someone on this site would know how to do this I would really appreciate any info thank you very much Bryan
  • Bryan
    Simply unplug the shore cord and plug into the generator
    But I think maybe you are looking for an automated system
    That requires transfer switches, voltage sensing, and automated control circuits, to do a power transfer, when you are not home
    Not something a novice can simply connect with a couple of wires
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Ok, Two ways to do this.. Easy and complex.
    First. to be sure you need at least 3000 watts of generator, A Yahama EF-3600i is ideal, or a pair of Yahama or Honda 2000 watt units with parallel kit.
    Simply plug into the 30 amp outlet if needed use the proper adapter.. That's all folks.. Job done (One A/C) 5500 watts if you have 2 A/C's.
    The complex way.
    Find the power line to the A/C.. note on some RV's there may be devices between the circuit breaker and the A/C.. you want the last length of wire to the Roof.
    Disconnect at the lower end and run a new 12 ga line with and outlet on the end of it to the point you just unhooked from, Hook it up, the outlet needs to be in a place you can access from outside.
    A 2nd length of 12ga (I used two halves of an extension cord) runs from the end of the wire (use a proper junction box. LEVER NUTS (tm) or solder work better than wire nuts) and this line has a plug.
    Normal operation Plug plug into outlet.. the circuit is now exactly what it was when the RV left the factory.
    Generator running A/C only: Pull plug and using a 12GA cord (I really like the ones Sears and K-Mart sell with the push button on the outlet) extend to the generator, again you need over 2,000 watts, a Yahama EF 2400i MIGHT do the job.
  • What is to wire? Just start the generator and plug in. At least post the make and model number.
    Or do you want a built-in generator that auto starts when power fails?
  • Many generators do not have enough capacity to run AC.
    Is this gen built into the trailer or is it external ?
    Assuming it is external, you unplug the power cord from the campground post and plug it into the generator. You should NOT have both connected at the same time.
    I have a feeling I am missing something here though.
  • looks like you're trying to post pictures stored on your computer. Please go to Forum help and support and learn about posting pics.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
