Vulcan_Rider
Oct 18, 2015Explorer
BFL13 wrote:
Your two 6s seem to be working well.
You put in the new batteries to get a higher capacity.
Among other things, that means that they need more charging capacity too. Your present solar may not be able to give them enough charge fast enough to really care for the new ones properly.
IF....you had a long, bright sunny day and the batteries started out close to fully charged.....you might see a higher charging voltage than what you have seen so far but I kind of doubt it.
Or to put it another way, it might take the present solar system several days to fully recover from one healthy overnight discharge if no other charging source is used.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
