Gdetrailer
Oct 08, 2013Explorer III
DutchmenSport wrote:
This should be interesting, "how many RV.net-ers does it take to change a lightbulb?"
at least 5000 RV.netrs to give advice on WD, brake controllers and what brand and type of tires the OP shouldn't use instead of helpful advice of how to remove the bulb... :S :B
Most bulbs as long as they have the flat plastic plug in base should pull straight out but they can get difficult to pull out.
If your fixture has a bulb number listed you can look up the bulb number and take a good look at the base just to make sure it pulls striaight out.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
