j-d
Jul 06, 2017Explorer II
Many of us have run into this issue with various Fords. Some engineer got the bright idea to put the A/C Vacuum Reserve Chamber and Check Valve INSIDE the HVAC Cabinet. I have two threads that shows how I fixed ours. It's easy and inexpensive.
My thread on RV.net Class C
Lengthy Thread on BATAuto.com
Long and Short of it is This:
To diagnose it and quickly get to what took me HOURS:
1. Get some 5/32" Vacuum/Wiper Hose
2. Find the RED "hose" (actually plastic tubing) near the Transmission Dipstick and the HVAC Accumulator (black metal can coffee sized). Should join to Black at a connector you can pull. With engine idling, feel for vacuum on the RED end. Got Vacuum, Right? Re-Connect to Black
3. Go into the passenger side foot well, and look forward to the firewall. Find the BLACK plastic tube. Cut it, leaving a couple inches where it comes out of the plastic HVAC Cabinet.
4. Engine idling, feel for Vacuum on the ends of that cut hose. If the problem is what I think it is, you will NOT find vacuum.
5. No vacuum on that cut hose... You need to do two things now:
6. Bypass the vacuum system from where you unplugged Black from Red under the hood, to where you cut Black inside.
7. Provide a Check Valve and Reserve Tank to keep the A/C controls working when you open the throttle and engine vacuum drops.
The threads show the common Dorman part numbers I bought. With the Check Valve, the Tank, and the Vacuum Hose, you can do all that. Cut the Black tube under the hood beyond the connector to Red. Connect the Dorman Tee Check Valve there, and run one side of the Tee to the Tank.
You can get the hose down into the fender, toward the door post. Then find and poke a hole in a grommet in the door post. Pull the hose through and connect where you cut.
There are various places to hide the Tank. I put mine under the hood, behind the air filter, where I found a couple little brackets. There IS a tank with the check valve built in. I chose to hide the tank, hope it'd never fail, and put the check valve where I could easily change it. I've had to replace it once already.
Let me know if I can help.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 21, 2026
