blueh20's avatar
blueh20
issues syncing controller
hi, am a newbie so looking for guidance.
My setup:
lifeline 8dl 255ah battery, 3-100w renolgy eclipse panels, 40amp commander controller.
I also have between batterys a blue sea charging relay ML-ACR. A 40amp fuse between controller and battery.
House battery is the "main battery" in my setup and the starter battery is the aux.
Have the MT50 digital solar gauge, and a Xantrex "linklite" gauge that will let me monitor the house and starter battery.
I hooked this all up a couple of years ago with the help of the folks on this site. All seems to be working well other then the solar charging the battery fully.
When charging off the panels, The house battery is the "lifeline", the MT50 shows fully charged but the Xantrex will show 12.8 and be 2 bars short of full.
When charging off of a battery tender the MT50 shows about a 1/3rd full and the xantrex will show 13.8, but still be 2 bars short of showing full.
That is the Lifeline house battery. When I hit the button on the xantrex to check the aux battery(starter battery) it will show the same volts 13.8 but the aux battery will show full bars on the xantrex.
Just seems as though the commander controller or the xantrex is synced incorrectly by me.
On the face of the xantrex it shows to push the two outside buttons to sync things, im thinking I did something wrong, any ideas.
Anyway to cancel the sync and let the controller charge higher up around 14?
thanks for your help.
