SCVJeff's avatar
SCVJeff
Hughes RV220-50 really working?
Does anyone know how this autoformer really works?
I ran both phases up through a dog bone on a Variac tonight and watched L1 switch to boost around 93-95 volts, and the switch to bypass a little above 115vac just as the book says. However, measuring L2 showed it in bypass at all times. This test was unloaded.
I thought these were two transformers running independently, but see that if I only power up L1, L2 also has voltage on it's input. But looking at the outputs, they follow whatever input is powered.
These results don't sound correct, but doing a load test is difficult. I would expect L1 & L2 to act the same. Shouldn't they?
  • I think it should boost 2% in all conditions and 10% as input approaches 112 volts.
    The legs are independent.
    Test with at least 100w load and use a true RMS meter.
    Yes the boost seems to come in late(L1) or not at all(L2).
  • I thought these were two transformers running independently, but see that if I only power up L1, L2 also has voltage on it's input. But looking at the outputs, they follow whatever input is powered.
    My guess would have been one transformer (120/240 in and out) with the boost coils on both L1 and L2 outputs which would explain why you can power one input and get voltage on both outputs.
    It does sound like the L2 output is defective since it it always in boost.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Sounds like it is defective to me.. Check with the manufacturer,, Good test procedure by the way.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
