Sez Hoo! wrote:
If you look at a multi voltage motor, the lower the voltage the higher the amp draw. That is true for an inductive load. For a resistive load like electric water heaters the opposite is true.
Like everything in physics, one cannot get something for nothing. An Autoformer cannot maintain the same energy into an RV by doing it with a higher voltage that it manufactures from thin air - whether or not any load inside the RV is resistive, inductive, or any combinaton of the two. Current flow into the Autoformer MUST go up for it to deliver the same energy, at higher voltage regardless of load type, than the RV was using before plugging in the Autoformer. However, I'm open to looking at any equations that might show how an Autoformer can increase the voltage for all loads without increasing it's input current draw ... unless the Autoformer is merely a power factor correction unit ... which means it would be of no use in increasing the voltage into an RV if the RV was presenting only resistive loads at the time.
This is a complete FWIW explanation, as I'm sure all Autoformer users will continue to marvel at them. I probably would own one if we used hookup campgrounds enough to justify the cost. However, they have to lower the voltage a tiny bit for everyone else in an already over-loaded-electricity-wise campground .... unless they are only a PFC unit for only inductive RV loads.
Here's a longer and probably more clear explanation of what is going on that gives rise to the complaint that Autoformer users in a campground are "stealing power" from the other campers during times when a campground can't deliver high enough voltage to it's campsites:
http://www.damouth.org/RVStuff/Autoform.shtml
