qwerty11's avatar
qwerty11
Hurts Gen or AC when stumbling to start AC in ECO mode?
I like to run the Champion 2k on ECO mode as it conserves gas when the compressor on the AC isn't running. However when the compressor kicks on the surge bogs the generator for a second, during this time period the fan stops on the AC, the generator then spools back up, and the fan comes back on along with the compressor. My question is, is this harmful to the generator or AC?
Thanks!
  • DryCamper11 wrote:
    Gens don't usually like to start at full load. )
    Not in Eco mode. He'd be fine turning that off... but, that's still a heck of load on a 2k gen.
  • There are several - "It's bad, don't do it." comments, and they are probably right. That's my first impression, too. But the reason it's bad for the AC compressor to run at low voltage is that the motor needs a certain amount of power, and at low voltage, it takes more current to produce that power. As the current goes up, the heat produced in the windings goes up as the square of the current. Heat is bad for motor windings. It's possible that momentary low voltage sags do not produce enough heat to significantly injure the windings, as long as you get the voltage up reasonably quickly.
    I'm not saying the comments are wrong, but I doubt anyone has done any real testing on this issue, and it's possible you are doing no harm at all - at least not to the AC. However, you'd be doing something that has the potential for harm and all that can truly be said is that the system isn't designed for that type of operation.
    The gen might not be happy either, although I don't know much about your champ. Gens don't usually like to start at full load. So you are left with the choice of either trying to get into the region the equipment was designed to run in, or doing experiments and possibly busting expensive equipment. :)
  • bob213 wrote:
    I would think you are slowly killing the compressor.
    X2. Jb
  • I agree it will eventually hurt the motor if it drops too low. Without connecting something that will monitor the voltage you just won't know if it's dropping low enough to hurt it.
  • Over time, I would say yes. That's one heck of a voltage sag. You would be better served by paralleling with another.
    It's likely you're also working the Champ to death running that air.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
