Henry_Wall's avatar
Henry_Wall
Husky Brute A Frame Jack
Can the Head on the Husky Brute HB4500 A Frame Jack be rotated on the shaft it is so close to my Propane tank cover it is hard to get the cover off to open or close the valves on the Propane Tanks
  • A quick Google indicates that the head will not rotate. You will need to drill new holes in the mounting flange.
  • Do you have the manuals that came with your Husky Brute? If not, you should be able to find them on line.
    The Husky Brute literature should tell you if you can or not.
    I know the Barker power tongue jacks can be rotated. I rotated mine so I could lower the tailgate while hitched.
