dougrainer
May 27, 2018Nomad
When it sticks, if you unplug the dash control panel and the pump stops, you have a bad touch panel. One thing you stated, it appears your system was NOT OEM. It was installed aftermarket. If so, then I would suspect the wiring harness from the touch pad to the Pump assbly has a short caused by being cut or melted. Doug
