kmb1966's avatar
kmb1966
HWH Fuse holder melted - wire gets hot when storing jacks
I am experiencing a problem with my HWH Jacks. The jacks operate fine, raise the coach, retract with no issues. But upon retracting (pressing the store button) the inline 40 amp fuse holder (by the pump) completely melted and was smoking. Called HWH and they said to replace the corroded fuse holder. I removed the melted fuse holder, replaced with only a new 40 amp blade fuse to observe. When raising the jacks, the wires and fuse itself stay completely cool. But when pressing the "STORE" button, the jacks retract, but the wire and 40 amp fuse itself get very hot. Fuse does not blow, but the fuse and connectors are very hot. Anyone have an idea on what the problem could be? I don't want to simply replace the fuse holder, because I think it will likely just melt again. seems to be a problem somewhere, but I don't know where to look next.
2001 Itasca Suncruiser
HWH Model 310 Leveling jack system.
  • In a similar "hot fuse holder" situation, I removed the fuse holder and upgraded it to a higher quality one.
    That Maxi fuse holder linked above with a 40A Maxi fuse will prolly do the trick.
    I take it the wires some distance from the fuse/holder remain cool?
  • The difference is ATC fuses are sealed and ATO isn't. So in a clean, interior environment the cheaper ATO is fine but otherwise, the ATC is best.
    There is no other functional difference.
  • Still working on this. The 40 amp fuse does NOT blow. I am using a blade fuse labeled 40 amp ATC. Is that the right type of fuse?
    If I put in a 15 amp fuse, it will blow when I press Store, but it does not blow the 40 amp fuse.
    I cleaned up the connectors and made them tight on the fuse. It seems the fuse and connectors now get fairly warm, but not scorching hot as before. But the 40 amp fuse does not blow. Want to make sure I am using the correct type of fuse. I don't know ATC from ATO type fuses
  • does this system use a single 'dump' valve for all jacks ?
    its 'odd' that you can run a pump and multiple valves while 'extending' the jacks to level
    but blow a fuse on retract, when the only load is open one or more valves
    could the power control wire for the dump valve be shorted, or the dump valve coil be bad, it should be getting hot if it is blowing that 40 amp fuse
    i would check those coils for 'excess' heat
  • A pic would help. The resistance could be where there's a connection to the fuse holder, a crimp or the holder itself.
  • In STORE, the only real draw is the 4 solenoids. The solenoids used to be on 4- 10 amp fuses. 1- 10 amp per solenoid. What your problem points to, is, something in store is pulling excess current. The solenoids operate the same in extend. So, you need to observe if that fuse holder gets HOT like it does in store. I will bet it does. Your problem is, you NEED to replace the fuse holder. It has been compromised by the previous failure and THAT will cause resistance and heat. I would also disconnect each solenoid 2 wire quick connect 1 at a time and see if one of the solenoids is causing the heat. You could also disconnect all 4, hit store and see if the wire gets HOT. If NOT, then 1 of the solenoids is failing. Do NOT run in store more than 10 minutes. Those solenoids cannot withstand a constant power to them. After 15 to 30 minutes the coils WILL overheat and destroy the solenoid/s. Doug
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
