georgem2106's avatar
georgem2106
HWH leveler issue - baffled
I have one leveler that leaks fluid intermittently. It first happened two weeks ago at a stop then the next two stops didn't leak. Stopped for the night yesterday and it leaked again. It seems to leak maybe 3 to 4 ounces. Anyone have an idea?
  • Rebuild or Replace the Cylinder. That is the only fix if the seals leak. Doug
  • diazr2 wrote:
    I have HWH and if I don't put the joy sticks in the neutral position it will leak at the jacks.
    HWH jacks should NEVER leak under any situation. Doug
  • I have HWH and if I don't put the joy sticks in the neutral position it will leak at the jacks.
  • Could be the fitting or the cylinder itself.
    Have to get under and figure it out. Get a mobile mechanic if need be.
    I had a cylinder leak a while back. Had it removed and repaired locally.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
