pweekly's avatar
pweekly
HWH pump keeps running
Hi all
I had posted last week thinking my level control switch might need replacing due to the pump running when I start the motorhome and then stopping when I selected the off button (but then running again when I would release the off button). I went to open up the slide outs and same thing. The pump will open the slides no problem but then continue to run continuously for a couple of minutes. In a non-technical way (if possible) can you help me troubleshoot this? Thanks so much.
Trish
  • rockylarson wrote:
    I would start with a pump reservoir fluid level check.
    Fluid level would not have an affect on this type problem on a HWH system. I would suspect a bad pump solenoid. Doug
  • Sounds good and about my technical level. LOL Thank you.
    Trish
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jan 17, 2025
