Calicajun's avatar
Calicajun
12 Volt Water Pump Keeps Running
This has not been my week for trailer repairs, lot of little things to fix. So far the repairs I have made are working out fine but there is always that one item.
For some reason the water pump is not shutting off. It stays on just a little bit, not like when you open a faucet just a very low humming it never did before now. Also don't seem to have the water pressure I think the trailer should deliver. In fact the outside shower doesn't get more than a drop or two of water and that is both before and after replacing the shower valve unit (another repair story).
Can't find any leaks now after going through and tightening every fitting that could be found. Let the pump run for a few minutes to see if I could spot water building up somewhere in or under the trailer but found nothing. Didn't see any water build up the four days camping when connected to city water either. City water pressure is better than pump pressure but not a whole lot better.
Any ideas of suggestions. I hate the thought of having to take the trailer in to a RV service repair shop.
Thanks,
Craig
