I am new to using HWH levelers and need guidance. I use auto level and everything works fine. Sometimes, my front wheels lift off the ground when RV is level. I want to put my leveling blocks under th...
I would pull on to the blocks first, then level. I'm not 100% certain of the HWH leveling algorithm, but I suspect manually raising, then doing auto level would simply raise the rear to match- I don't think it is programmed to lower on auto, just raise. You could raise, then fully retract and auto level if needed.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
