I am new to using HWH levelers and need guidance. I use auto level and everything works fine. Sometimes, my front wheels lift off the ground when RV is level. I want to put my leveling blocks under th...
If the front tires come off the ground in Auto level----Raise the front a few inches more. Install the blocks under the tires. Then MANUALLY retract the front jacks until the YELLOW light for the front goes off. You may have to raise the rear a few inches also. Just follow the Yellow level lights. HWH will NOT retract to auto level. You could put the blocks under the tires then do a full retract and then Auto level again. Doug
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
