MrWizard
Dec 05, 2018Moderator
Ivylog wrote:
$1300 for a 3kw of power plus $15K for the Prius that only has a 150AH battery at 12V.....yes 6.5A at 200-250V. Engine will have to run most of the time. For $1300 I can buy a 6KW generator and syphon the gas out of my Prius.
Not using the 12v battery, you could just connect a regular inverter and not buy that set up
That system connects to the EV battery system
Engine is off until the battery reaches a certain discharge point then cycles on and off like when driving
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
