pigman1
Dec 11, 2018Explorer
Are you talking about HWH jacks? HWH has some very specific directions on these hydraulic rams. There is other info presented in HWH instructions. Download it and read.
ISSUE DATE:
HWH CORPORATION
R
Cleaning the jack and jack rod.
In general, HWH jacks require no regular maintenance. Under normal circumstances, lubrication of jack rods is not necessary or advised.
If a jack gets coated with dirt or mud it is advisable to clean
the jack. It is acceptable to clean the jack as a part of normal maintenance but is not required.
Note: The 9000# and 16,000# kick down jacks have a roller bearing above the actuator rod.
This bearing must roll freely for proper operation of the jack. It is a good idea during regular maintenance
that this bearing is checked to make sure it does roll freely. If the bearing is frozen or does not roll freely,
use WD-40 to loosen the bearing and then apply a few drops of motor oil (used is fine) to lubricate the
bearing. See diagrams on reverse side.
BLOCK FRAME AND TIRES SECURELY BEFORE CRAWLING UNDER
VEHICLE. DO NOT USE LEVELING JACKS OR AIR SUSPENSION TO SUPPORT VEHICLE
WHILE UNDER VEHICLE OR CHANGING TIRES. VEHICLE MAY DROP AND/OR MOVE
Basic cleaning of the complete jack assembly is accomplished with the use of soap and water.
Spaying the jacks with a spray wand at a car wash would be acceptable.
The only time a jack rod would need cleaning is if the jack has been extended for a period of time.
The jack should not be extended just to clean the rod.
WARNING:
If the jack is extended, use soap and water or WD-40 on the jack rod then wipe the rod dry with a clean cloth.
Do not use a dirty rag to wipe the jack rod or do not wipe the jack rod if it is coated with dirt.
This could scratch and damage the rod. Make sure to use water or WD-40 to loosen any dirt before
wiping the jack rod.
If the jack rod has been greased or silicone sprays have been used on the jack rod, use WD-40 to loosen
the grease or silicone and wipe the rod clean.
ISSUE DATE:
HWH CORPORATION
R
WARNING:
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
