olympicman's avatar
olympicman
Hydraulic Hose leak.
I have the HWH Jack and Room slide system in my 2010 Rexhall Aerbus. One of the room slide hydraulic hoses has a hole worn in it.
The hose is a Parker Parflex 1/8" PDH-2 6000 psi. Best way to fix would be to replace hose, but access to the ends looks near impossible. Could the hole which is in the middle of the line be cut out and new 58 series fittings put each hose end and something put between to tie the lines together, "threaded Pipe or something else"?
  • any good hydraulic shop will have the connections you need. Cut the hose new fittings that tie the 2 pieces together and you are good to go.
    I have done this on a a hose to my jacks and also to the hose fom my slide. Did this many years ago and no more leaks.
    Busyguy
