olympicman's avatar
olympicman
Hydraulic Hose leak.
I have the HWH Jack and Room slide system in my 2010 Rexhall Aerbus. One of the room slide hydraulic hoses has a hole worn in it.
The hose is a Parker Parflex 1/8" PDH-2 6000 psi. Best way to fix would be to replace hose, but access to the ends looks near impossible. Could the hole which is in the middle of the line be cut out and new 58 series fittings put each hose end and something put between to tie the lines together, "threaded Pipe or something else"?
Having RV issues? Connect with others who have been in your shoes.24,263 PostsLatest Activity: Jun 09, 2025
