Hi All, I have a Wildcat 28BH with a single hydraulically actuated superslide. We haven't used the rig in a couple of years and I see that all of the hydraulic fluid has leaked out onto the ground...
it should use ATF. Are you sure Lippert has nothing on your system? If you go to http://lci1.com/support-center, click on the slide setup you have, and you will get a tabbed page, with tabs for technical info, manuals, faq, etc. The manuals will give the service manuals.
