darsben
Oct 10, 2013Explorer II
The owners manual troubleshooting guide is here
http://bryantrv.com/docs2/docs/hflamefurn04.pdf
First thought should be the sail switch as you said there was debris in the area.
Sequence for ignition is
1 call for heat
2 blower starts
3 sail switch closes because of air movment
4 ignition circuit check
5 ignition.
So the first thing to do is find the sail switch and check it
1 call for heat
2 blower starts
5 ignition.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
