dougrainer
Apr 06, 2014Nomad
How did you confirm your furnace draw and what made you trace a draw and to the furnace? Did you disconnect the 12 volt power to the furnace and your draw went away? What type tool did you use to measure that .5 amp draw? I do NOT believe a correctly operating furnace has any parasitic draw when not being run. The circuit boards do not draw any current when the system is OFF on a correctly operating furnace. SAME with a DSI Water Heater. The use the same basic module board. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
