wa8yxm
Feb 22, 2020Explorer III
Some (about 14.5) years ago I needed to find my ATS.. So I sat down and visualized where the shore power inlet is (a long way away) and where the generator is (Fairly close) and where the two paths crossed. Then I found a panel blocking a cupbord. removed the panel and dang near passed out in shock (The Surprise kind not the electrical kind) There is was. RIGHT WHERE LOGIC SAID IT SHOULD BE..... That's very odd and normally would be the last place I'd look in an RV (Ok so I'm joking a bit) but I an tell you several other sub systems are a long way from logical.
On a trailer I will go with the "Poor Man's Transfer" (an outlet you plug into) as the most likely.. Otherwise it's good luck finding it.>> I've tracked down a few of 'em and Mine is the only one that was where it belonged.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
