- BurbManExplorer IIICW?
- RJsfishinExplorerQuote:
............ through my PD9160 all the time......once in a while my batteries are to far discharged......in that case I charge them with the on board ONAN
Why in thee world wouldn't you just grab a lower gear on the CW ??
If you don't have a CW connected, get one ! - 2oldmanExplorer II
NinerBikes wrote:
Excellent idea.
If the price is too good to be true, please verify that the product isn't stolen, - 96Bounder30EExplorer II
mlts22 wrote:
A 1000 watt generator has two uses in a motorhome for me, especially since it is small enough to be put somewhere in the RV and forgotten about (assuming it is stored properly with a drained carb, the fuel is fresh, oil changed, etc.):
1: Something that is used with a Schumacher charger to get power to the batteries so the onboard genset can be started, if the house batteries are very depleted.
2: If boondocking and the MH doesn't have an inverter, it can be something to power the 120VAC side for low wattage loads. Stick it on Eco-Throttle (where it will chug on its fraction of a gallon gas tank for 12-15 hours), use it for charging laptops, shavers, smartphones, and so on. (This is assuming nobody else is around for etiquette's sake.) It also helps offset the power loss from the RV's furnace fan if someone doesn't have a solar charger or many amp-hours.
As an emergency generator or one just to power low loads without having to fire up the main genset, having a small 1000 watt Honda can come very much in handy.
I use my Honda 1000 for recharging my 2 6 volt Trojans through my PD9160 all the time......once in a while my batteries are to far discharged......in that case I charge them with the on board ONAN for about 20 minutes then switch over to the Honda.....
Normally, I only use my ONAN for microwave use, vacuuming and hair drying......
I would dislike dry camping very much if I did not have the Honda 1000 - NinerBikesExplorer
Just Lee wrote:
I found this generator and it is close to home so I can go look at it. The PRICE is awesome. My question is what should I do (take with me) to check it out before I buy?....
Thanks
If the price is too good to be true, please verify that the product isn't stolen, or that you are supporting theft by being in possession of stolen property.
Supporting your local thief, tweaker druggy or local fence/pawn shop is frowned upon. Get a serial number and check with the local Sheriff and Police departments for stolen units. - mlts22Explorer IIA 1000 watt generator has two uses in a motorhome for me, especially since it is small enough to be put somewhere in the RV and forgotten about (assuming it is stored properly with a drained carb, the fuel is fresh, oil changed, etc.):
As an emergency generator or one just to power low loads without having to fire up the main genset, having a small 1000 watt Honda can come very much in handy. - Just_LeeExplorerI have a meter I can take and a small heater. Maybe a hair dryer that has 2 settings (but I can't read the label) Hmmmm maybe a drill motor.. Ok the wheels are turning LoL
- Community Alumni"A 1500 Watt Space heater will put Good load on it."
I'll say! It's only a 1000 watt genny. - rv2goExplorer III would also take a volt meter. My 1000e puts out 122volts at 4amps or about 500wats. Check the idle. Carbs jets can become fouled.
- othertonkaExplorerA 1500 Watt Space heater will put Good load on it.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 05, 2026
