Dennis_M_M
May 03, 2014Explorer
Not an electrician, but a good RV or auto tech for that wiring. Those yellow and red screw-on connectors are fine in a static building, not so good in an RV - sooner or later they will work loose. All of those should be crimped or soldered butt connectors.
The wiring should also be secured so it does not move around all the time while you are on the move.
Bench cover should not be nailed in place as you need occasional access.
As far as the plumbing goes, the fewer the connections the better, that one looks a bit Rube Goldberg.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
