Iowa_Cowgirl
May 03, 2014Explorer
CaptPicky wrote:
It's hard to tell what type of fitting is that black fitting. I wonder if the hose coming from the left is to big of inside diameter for the black fitting. If there is to big of difference screwing down the clamp won't help. Take the metal clamp off, if the hose is really lose that might be a problem.
I did that and yes, it's loose. What should I do?
I'm also not sure why there is a shut off valve right there. That is the water source for the trailer, unless the shut off valve is to turn it off in the event there is a leak found down line. Is that the reason?
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
