Bill_Satellite
May 03, 2014Explorer II
What is connected to the other end of the clear braided hose? Where's that water coming from?
As a side note, if you hear a lot of noise when your water pump is running it is likely due to it being plumbed directly to the PEX type lines. It is generally recommended that you isolate the connection with a flexible loop of tubing (like the clear braided hose) on the input and output side. Doing so will quite and isolate that noise.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
