Iowa_Cowgirl
May 03, 2014Explorer
Bill.Satellite wrote:
What is connected to the other end of the clear braided hose? Where's that water coming from?
As a side note, if you hear a lot of noise when your water pump is running it is likely due to it being plumbed directly to the PEX type lines. It is generally recommended that you isolate the connection with a flexible loop of tubing (like the clear braided hose) on the input and output side. Doing so will quite and isolate that noise.
Okay I'm not going to change over to PEX. Too expensive and I'm about tapped out on spending much more money on this project.
That hose is connected directly to the fresh water holding tank. Here's a side by side photo so you can see more:
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
