Iowa_Cowgirl
May 04, 2014Explorer
MrWizard wrote:
If I'm looking at the above picture correctly
The water pump is mounted on one of the vertical panels of that cabinet/bench ?
The panel is acting like a sounding board aka speaker cone
On the floor with Thick rubber mounts would be the quietest
It's mounted on the floor under the bench seat. It's mounted on two thick rubber mounts. I found the culprit to the noise. One of the pipes is vibrating and hitting the vertical backside of the bench. I ran the pump when I was draining the tank (again) and found the vibration. Should I clamp the pipe to the bench or just pad it between the pipe and wall. I shoved a can cozy between the two and it stopped the noise but hey...I need that can cozy for my beverages!!! lol Please advise.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
