2oldnslow
May 04, 2014Explorer
Iowa Cowgirl wrote:
It's mounted on the floor under the bench seat. It's mounted on two thick rubber mounts. I found the culprit to the noise. One of the pipes is vibrating and hitting the vertical backside of the bench. I ran the pump when I was draining the tank (again) and found the vibration. Should I clamp the pipe to the bench or just pad it between the pipe and wall. I shoved a can cozy between the two and it stopped the noise but hey...I need that can cozy for my beverages!!! lol Please advise.
I hear you on the can cozy - that is much too important a tool to be used for cushioning!
I would find a piece of foam (like pipe insulation) to put in there. If you clamp it to the bench it may still make a fair bit of noise and may even cause leaks down the road. Those pumps move around a bit while working.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
