Iowa_Cowgirl
May 05, 2014Explorer
2oldnslow wrote:
I hear you on the can cozy - that is much too important a tool to be used for cushioning!
I would find a piece of foam (like pipe insulation) to put in there. If you clamp it to the bench it may still make a fair bit of noise and may even cause leaks down the road. Those pumps move around a bit while working.
Excellent advice! I have to run into the city today for some other errands and am taking this with me to find higher quality plumbing. This is a photo of the assembly between the tank and the pump. It's ALL leaking, no matter how tight/loose/more pipe tape..none of it is working. Those butterfly type connectors leak plain and simple.
I can check this forum from my phone so if y'all have some suggestions for plumbing to replace what I've shown, I will have access to Menards and Lowes while in the city. I live over an hour away from the city so advice will be helpful. Thank you.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
