NinerBikes
May 05, 2014Explorer
A boyfriend with some strong hands and handyman skills could save you a lot of headaches with your rig... don't cowboys, ranchers or farm hands twist pipe wrenches anymore, for a few good home cooked meals?
Replace all the o ring rubber seals in those butterfly connections, and make them snug, do not over tighten... that whole system needs to be able to move around and have a little give under there while you go bouncing down the road. If you drive dirt roads, and washboard, you're flat out just going to have more wear and tear on everything in your trailer, including all the plumbing and all the electrical, with is designed for stationary use.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 16, 2026
