mena661
Jun 06, 2014Explorer
BFL13 wrote:Whipping out that manual again! :) Here's what it says:
I wonder what will happen when your solar gets to Vabs 14.8 and your batts are at 95% SOC and amps are 5 amps but just then a cloud goes by and your amps drop to 0.00001 for a while. Will it reset?
In case of a 12 V battery, the BMV resets to “fully charged” when the following “charged parameters” are met: the voltage exceeds 13.2V and simultaneously the (tail-) charge current is less than 4.0 % of the total battery capacity (e.g. 8 A for a 200 Ah battery) during 4 minutes. The BMV can also be synchronised (i.e. set to “battery fully charged”) manually if required. This can be achieved in normal operating mode by holding the + and – buttons simultaneously for 3 seconds, or in setup mode by using the SYNC option (see sect. 3.4.1).
I have not set the "tail" charging setting cause I don't know what that is. Mex, I can actually set CEF in the meter. Don't know how to determine that though.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
