mena661
Jun 06, 2014Explorer
Bend wrote:Dang new fangled phones!
Mena & BFL- Bet you two still use rotary phones. You's gotta try those with a push button. 8>)
BFL,
More manual goodness! These are some parameter settings.
Vc: Charged voltage.The Vc can be set from 0-90V, the It setting can go down to .5% and the Tcd can be set from 1-50 minutes.
The battery voltage must be above this voltage level to consider the battery as fully charged. Make sure the charged-voltage-parameter is always slightly below the voltage at which the charger finishes charging the battery (usually 0.2 V or 0.3 V below the ‘float’ stage voltage of the charger).
It: Tail current.
When the charged current value is below this percentage of the battery capacity (Cb), the battery can be considered as fully charged. Make sure this is always greater than the minimum current at which the charger maintains the battery,or stops charging.
Tcd: Charged detection time.
This is the time the charged-parameters (It and Vc) must be met, in order for the battery to be considered fully charged.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
