pnichols
Jun 06, 2014Explorer II
MEXICOWANDERER wrote:
Charge the batteries utterly and totally 100% according to the hydrometer. Discharge the batteries 50% of amp hour capacity according to your AMP HOUR METER. It danged well better agree with a second hydrometer dip.
There might be a problem with that. How do you discharge batteries 50% of ORIGINAL as-bought capacity using indications from any kind of in-RV metering system?
I suspect that hydrometer and amp hour meter readings can only show 50% of fully charged capacity at whatever capacity the batteries were capable of when taken to full charge the most recent time.
Doesn't the as-new capacity of an LA battery slowly but surely decline over time as their electro-chemistry and materials age? How can an amp hour meter know this rate of decline and hence know the battery's % of as-new capacity?
What I would like is some kind of RV metering system that would show fairly simply and inexpensively - and while leaving the battery(ies) in your system - what the capacity of your battery(ies) is(are) "now" ... as compared to what it was that you paid for and got when you bought the battery(ies) new.
Case in point - my ~7.75 year old RV batteries "seem" to charge fine and sill last "quite a while". However, I'll bet they don't make up a 200 amp hour capacity battery bank anymore. And as I understand it, the only way to determine their present total amp hour capacity is through dynamic load testing, which is NOT convenient to do or have done.
I'd like some way to tell the battery bank's State-Of-Aging while it's still mounted right in the RV - fairly accurately at any time -> about how worn out my RV battery(ies) were getting regardless of whether they still "fully charge" well via hydrometer readings and/or amp hour meter guesstimations.
The ideal would be a constant some-kind-of-meter reading capability showing what the current state of original capacity your RV battery bank was at any time. With this kind of setup, one could not only always tell when to charge .... but also when to replace.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
