dougrainer
Feb 06, 2019Nomad
You get a flat 3/16 aluminum plate just slightly larger than the imprint of the exposed area. You then use Dicor rood sealant and liberally seal the inner edge of the flat plate and use either rivets or flat head screws to anchor the plate. Make sure you cover the existing hole from the inside to prevent Dicor from oozing out and falling down into the interior. The Dicor and screws will glue the plate securely and will not leak and no need for Eternabond. Then from the inside drill 4-- -1/2 inch holes at each corner of the old wood square and then cut your 14 by 14 inch hole in the aluminum plate. You have a good repair that will support anything and you can attach Anything to that plate. If you want after the Fantastic install just use extra Dicor to cover the added plate and nobody will know what you did. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
