joshuajim
Sep 30, 2019Explorer II
MEXICOWANDERER wrote:
No do them separately and use a hydrometer, to verify the weak sister cells. Ideally, each 2-volt cell would be available. That ended when the over-the-top tartop batteries disappeared.
The equalization Must be current controlled. 5 amps per 100 amps amp hour capacity or 5%.
MEX, you have mentioned using the 100w bulb to control amperage many times, but how are you actually measuring the amperage.
