pianotuna
Nov 17, 2017Nomad III
I want one!
Hi All, 500 mile range loaded to 80,000 pounds. 30 minutes to recharge to 400 mile range. It may be self driving, too. https://www.greencarreports.com/news/1113863_tesla-semi-500-mile-range-lowe...
pianotuna wrote:Good morning Piano Tuna. You won't have any problem charging an electric vehicle with a 15 amp 120 volt. It just goes sloooow. So in other words when you get home you plug it in. Depending on the size of the battery you may have a full charge in the morning or not. If you just do normal commuting you won't have any problem with just your 120 volt plug. If you need a charge faster for an unexpected trip you can either pop into a fast charger. If there is none available there will be a level 2 charge point available somewhere at a mall or restaurant or city hall or library etc that although will not be a DC fast charge experience it will be at least 6 times faster than your home plug. All EV's come with a 120 EVSE for that reason. SO you can charge at home.
The grid is decrepit. In 1957 an 1100 square foot apartment only required a 40 amp service. A building with 43 suites has a main fuse of only 1000 amps. How do I know? I just paid for upgrading to 70 amps which including drawing #3 wire in a 1 inch conduit for 100 feet (with two bends).
I would be hard pressed to charge an electric car from the 15 amp service to my parking spot--but I hope to be able to afford to do so some day.
