dougrainer
Oct 27, 2014Nomad
Toyman1957 wrote:
This is an under the counter independent unit. It's only purpose is to make ice.
Make and Brand????? I will assume U line, as that is the most common stand alone in an RV. IF it gets cold(must be BELOW 10 degrees, the usual culprits are either the Tstat or if more than 5 years old, you will need a new mold/motor assbly as they usually get extremely rusted and corroded over the years and while you can buy the individual parts(120 motor-the bin switches and such), it is cheaper to buy the complete motor/mold assbly. This assbly is about $250 to $350 dollars and takes about 2 hours to replace. So, about $500 to $600 labor and parts. The tstat is about $75 and IF you just want to replace the motor and switches(comes as a unit) and NOT the complete mold assbly that part is about $95 to $115. Doug
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
