bsjones11's avatar
bsjones11
ice maker
I have a dometic NDR 1292 fridge/freezer. defrosted it the other day as I have many times and now the ice maker will not make ice. any help???
NOTE: Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions on how to post in the forums, signature and photo testing, reporting website or member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, create future threads in the RV FORUM which corresponds to the subject of your topic. Thank-you!"
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I have a new toy. well really a copy of an old toy. A wireless thermometer It is a 3 channel job and I now have two channels active on each of Two receiers
    it is as I type 77.1 Degrees where I'm sitting 60 even outside in the propane bay and 34.7 in the fridge.. (now you now why I mentioned the above)
    Move the remote I have in the fridge to the freezer (it just sits in a door tray not mounted) and if it's above 25 degrees NO ICE will be made That's how the ice maker knows it's time to cycle (Temp may be even lower)
    Make sure the arm is down
    Make sure you did not accidentally unplug the umbilical from teh back of the unit (The power wires)
Having RV issues? Connect with others who have been in your shoes.24,359 PostsLatest Activity: Feb 10, 2026
