Teebucket1313
Jul 02, 2013Explorer
Ice Maker
I took my motorhome to Coulee RV in West Salem Wisconsin for de-winterizing. They also did the winterizing. While they did the de-winterizing they siad the waterline to the Ice Maker was cracked. S...
Teebucket1313 wrote:
I took my motorhome to Coulee RV in West Salem Wisconsin for de-winterizing. They also did the winterizing. While they did the de-winterizing they siad the waterline to the Ice Maker was cracked. So they remove the refrigeraror to replace the line. Next they told the ice maker was not working and that had to be replaced. So after $700.00 plus they told it was fixed. We are heading to Texas so I was checking over the motorhome didn't check the ice make because they told me they had checked it. I'm here in Texas and the ice maker doesn't work. I remove the outside cover and see a red wire cut a taped from a temp sensor and a white wire cut tape coming fron the water solinode. I found the old wire harness that they cut when they remove the unit and it show the red and white wire connected,,,can I just connect the two wires? We have a New Dimensions Dometic refer.
Thanks for any help. No ice in Texas is rough.
Happy Camping, bye Dennis
