landyacht318
Jun 18, 2014Explorer
A problem with this is the cabling used between alternator and battery by the vehicle manufacturer, and why I suspect higher RPM's made no difference in BFL13's case. This cabling is not adequate to pass high currents for long, It was designed to be just adequate for the briefly lasting loads expected by the stock systems and a battery which never goes below 90% and can never ask for much. The bean counters won again.
This can be negated with a fatter cable between alternator and battery. I've done this, just adding a parallel circuit and the amperage increase is close to 60% when the house battery(s) are depleted and the RPM's are there.
I just have this pecky 13.7 volt issue where my engine computer located voltage regulator will randomly decide that 13.7 is fine and dandy, even when the batteries are crying for 14.8v.
Using an INverter on the engine battery to power a regular battery charger is Standard procedure In Australia, especially when the 'caravan' is towed and quite a distance from the alternator.
My alternator, rated at 130 amps can barely make 32 amps at hot Idle, so If I were to employ this system, I would be robbing peter to pay paul whenever idling.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
